Brief Description: Test Fit Interior & FAB Bracket
You have to keep several steps ahead of where you are working present, so you don't end up having to take things apart because you missed something. I wanted to see what kind of area on the walls of the fuselage I will have after the interior is installed. If I decided to run wire or tubes behind the interior was there going to be a conflict. Glad I decided to take the time. The interior side panels leave almost no room between them and the fuselage skin. I will run everything down the center floor of the aircraft. There is a tunnel there for the purpose. I also completed a bracket on the front of the FAB. This is not called for in the plans but recommended by those who's filter mount plates broke over time. I made it out of 1/2" SS tubing so should last and now no wiggle in the air box.
